The only real explaination was that it was a rigged demo to get you to buy their expensive cables, Monster (for example) are known for doing just this, where they compared composite cables with SD feeds, to HDMI cables with HD feeds, except they tell the people viewing the demos, that they're comparing their expensive pixie dust infused cables to "standard, low quality" cables.Or maybe they were beaming pixie dust in to my eyes and altering my brain waves as I was not wearing my tin foil hat. Sorry, couldn't resist but the fact is that only one cable was provided, it was HDMI as the projector was right next to me so I can see him plugging it in and out. I was told this cable will be good enough for most people at this level, done deal. I specifically asked for a comparison with a more expensive cable and we are not talking about hundreds of pounds expensive here, and saw a difference in quality. I believe the more expensive cable is HDMI 1.4 (or whatever they changed the name too) and the other cable was probably not supporting deep colour or able to maintain the higher bitrate at that length. If the retailer had offered the choice of the two cables and both were HDMI 1.4 then I would agree that there is a chance that there was some foul play going on but that was not the way it happened. The retailer though it was all a done deal with the cheaper cable. Again the 'Ripped off ' crowd (not including you here Kyle) don't know the full picture and just jump to the 'you're an idiot and got ripped off' mantra.
Correct, it's not the cable that determines the HDMI spec, it's the devices either side of the cable. There are two types of HDMI cable, one is a single link one (same as a single link DVI cable) and a dual link (would know known as high bandwith/speed), neither one effects the image quality in the ways you saw, "deep colour" isn't a cable spec either, it's more a display spec, with 10bit image processing, which isn't a feature of Blu-rays.So cables with different HDMI specifications (1.2 vs 1.4 for example) will not affect the picture quality?
You seem really hung up on image quality, and I get the feeling that you're ignoring how a system behaves when an inadequate HDMI cable is used, you seem to think it'll result in degraded image quality in the form of sharpness, saturation and contrast, when it's actually artifacts, the worse the problem, the more artifacts will be displayed until there's no image left.
USB 1, 1.1 and 2 use all the same cables, it's the ports and devices that determine the standard, USB 1 all the way to 2, use the same set up, 2 data cables, and 2 power cables (USB 3 uses a completely different cable with different wiring). So, as I keep saying, the cables for the most part are exactly the same, the cables themselves aren't what support the standards.Yes and I agree. What people do not seem to get past is that the cables may be of different HDMI standards. One might will have supported deep colour and the other may not. The one supporting should have exhibited better colour saturation should it not ? It is therefore like comparing USB 1.1 and USB2 cables and not USB2 and USB2 but more expensive.
RB
Of course 1080 wouldn't identical 1080p. That would also fall in to the category of "inadequate", you wouldn't use a cable with lesser bandwith than what you need, would you? And this isn't what we've all been discussing. What you're saying is implying I believe there is no difference in image quality different resolutions simply because it's using HDMI.
. A great service to the general public I am sure most will agree.
