Light up your life!
Be honest guys, was there ANY calculation involved at all when you came up with the figure of £700 saved a year? Not trying to **** on your bonfire, but a lot of people trust OcUK with the reputation they've built up, but making up figures only undermines this.
This - the figure got pulled about of someone's ****.
Unless you have some sort of small, floodlit stadium in your back garden....
Where does it say saving £700 per year?
Well... it doesn't really, it says we can "ave" £700 a year. Maybe this is a get out clause?
"Sir, i understand that you're upset that you only saved 50p a year with these, but we never said you could SAVE any money, you could simply "ave money" instead." ;)
When energy saving bulbs came out they weren initially quite expensive, i imagine these will come down quite a bit over the next few years if they are the next big advance in lighting.
A decent estimate is 10% of an electricity bill would be due to lighting. Let's say a little higher in the winter so assume 12.5% yearly average.
So a £1200 bill would see around £130 a year saving assuming those wattage figures are correct.
To claim a £700 a year saving your annual bill would have to be around £5600.
Indeed!
I think even this is a flawed estimate. I don't think you'd save anywhere near £130 off of your ENTIRE electricity bill with these. I was thinking you'd probably save about 20% off you LIGHTING bill over conventional energy saving bulbs.
Which means if your entire yearly bill is £1200, and 12.5% of this is lighting this works out as £150 a year for lighting. Then if you're saving about 20% of your lighting bill with these LED bulbs that means you save around £30 a year. "Great!" you think. Then you remember you spent £800 fitting out your house with these and it's going to take the next 26.6 years to break even.
Very good point. And with the cost of fitting out a "standard" house running into hundreds it would be many years before you got your money back.
It was the same when energy efficient bulbs first came out, they were too expensive and never lasted the stated 10 times longer.
I think even this is a flawed estimate. I don't think you'd save anywhere near 10% of your ENTIRE electricity bill with these. I was thinking you'd probably save about 20% off you LIGHTING bill over conventional energy saving bulbs.
Eeeek, that's some saving!
