- 8 Dec 2010
- Redcar, UK
EDIT: I's Ax 850 Gold, sorry for the mistype in the title.
Hi, just gor parts for first build, but must ask a few questions about the PSU.
Firstly...The 24 pin connection to the motherboard is fine, as there is only one cable, BUT for the 8/4 pin motherboard connection, there are two cables, both on the motherboard end have an 8 pin that you can split into 4, but the end that goes into the powersupply has an 8 pin and the other is a 12 pin. The 12 pin doesnt seem to fit anywhere, so im gessing the 8 pin is used, but just checking. Dont want to fry anything.
Secondly...some of the longer SATA cables have 4 sata connectors on. Should you only use one of these, or can you run, say, 4 SATA devices of one cable? Doesnt seem likely, but... And the same with the molex ones.
Thanks in advance!
Thanks in advance!
