Hi all, I'm having a few problems getting dolby digital output through my amp.
I have a Sky+ HD box connected via hdmi to the hdmi3 in port, with an optical cable from the sky box into the optical input1 port on the amp.
On the amp the digital audio is set to opt1 and the Dolby digital out is turned on within the sky settings. This seems ok to me, although I still don't get DD on DD broadcasts.
I discovered a different menu tonight from the 'Audio' button on the remote, and the audio select was set to hdmi. If I change this to 'opt' I lose sound completely. Signal format is currently set to 'all channel set' also.
What am I doing wrong? Thanks in advance, Grant.
