- 22 Mar 2009
- Cornwall
i ditched my cheap free mobo and got an ASRock 890FX Deluxe3 mobo. the cpu supported list is quite extensive and pretty sure it covers most, might need to upgrade from 1.8 to 1.9 bios though for some.
whats the difference between the standard and the BE chips?the Phenom II X4 955 BE - £101.82** is all you need
dont get a Athlon if you can get a Phenom. the Athlon as no L3
Dont get the Phenom 965 it's the same chip as the 955 with the multiplier 1 notch hire.
The 6 cores are VVVV Good but games only use 2 or 3 cores now so would be a waste of cash.
But that just my view
You don't really need to overclock but it would be a shame not to.
The X6 chips will be more future-proof, so save yourself some hassle and get one of those for the price diff. Both the 1090T and the 95W 1055T (don't even consider the 125W 1055T)
My experience is that the 95W version has about 250-300Mhz greater OC headroom.I do not think that there is significant difference with the 95W or 125W 1055T from feedback I have got. Both can run equally cool and as I have noted mine will overclock above 3.5GHz while substantially undervolted.
4GHz 6 core sounds pretty nicewhats the difference between the standard and the BE chips?
Agreed - with bulldozer due in Q2 this year, now is probably not the best time to be buying a CPU. Even if bulldozer power isn't needed, it still maybe worth waiting as PhenomII prices will surely drop when it's released. But if he needs to buy now for whatever reason then 1090T is my vote.what about waiting for the AMD balldozer?
quoted for truth!
In fact it would be rude not to.
It would indeed be criminal to leave a BE at stock clocks... imo no sane man would do such a thing! why settle for 3.2 when 4ghz is so easy?
