Well getting mine in the next couple of weeks already priced up powder coating it black inside and adding a window, (i know you can get a cm rdy modded one but dont like how the window goes over the drive bays) I shall also be getting this mod done as well: http://www.youtube.com/watch?v=PCr23YNU5vw
Apem you have a 230mm fan drawing cold air in from outside and blowing it straight over your hard drive bay. I've found this to be plenty but if you want to fit more there is provision to fit an extra 2 120mm fans on the other side of the hard drive bay which can be used as a push pull setup. Check this link and you will find a picture 3/4 of the way down the page showing this.
just buy an extra 120mm if you really must, and either add it to the floor infront of the psu blowing upwards, or stick it in the pci cooling box to add to the back.
