- 23 Apr 2008
Hi All,
This is my first post so I hope I have got it correctly located within the Forum. I have built many PC's over the years for personal use but have finally decided I would like to try out a water cooling solution.
I have Crossfired two XFX ATI 6970's on a gigabyte P67A-UD7 motherboard. The CPU is a Sandy bridge i7-2600K 3.40 GHz and sitting in a Cooler master HAF X gaming Tower Case.
After some research I have found the following which I believe will provide a complete set, however I'm not sure about the products or if I need any extra connectors or converters from the 1/2 inch to the 1/4 inch or if they are provided with devices, any advice on the setup and recommendations is greatly appreciated.
Water Cooling Kit:-
EK Full Cover Waterblock for ATI 6970: FC6970 Nickel Acetal * 2
Ybrix Black Sun CPU Waterblock for Intel 1155
Laing D5 (MCP655) Vario Pump for 1/2" ID Tube
Hardware Labs Black Ice GT Xtreme 560mm Quad Radiator : GTX560
XSPC 5.25" Dual Drive Bay Reservoir Clear: BR525Dual
Feser Aqua Cooling Fluid (bi-distilled) 1Ltr - plus thinking of mixing with 25% antifreeze
XSPC 1/2" ID - 3/4" OD(13-19mm) High Flex Tubing
Zinc Plated Worm Drive Hose Clip for 3/4" (19mm) Outer Diameter Tubing
Thanks for any help I receive.
Water Cooling Kit:-
