The more slots that are used up, the more "strain" it puts on the motherboard and reduces the maximum successful OC on the system.
More memory added after about 8gb doesnt really speed up the pc - it just allows more stuff to be open without slowing down the PC.![]()
I am running Win764 with 8gb of XMS3 (4 x 2gb sticks)
even working with CS4 i never use more than 6gb when rendering
on idle in Windows i only use 1.4gb
unless you are using cs5 i cannot see the point in going over 12gb
If you get a dual channel system youll be getting either 4 8 or 16, no point 12, however if you get a triple channel system then it becomes 6, 12 or even 24, which platform are you looking at?
The number of memory channels comes down to which platform you pick.You're right, why am I considering dual-channel? I'm assuming triple channel is better (from it's name and a quick google search!)
All AMD are dual channel.
Intel core i7 are triple channel
The shiny new Intel core i5 Sandy Bridge are dual channel.
I think the Sandy Bridge are generally regarded as the fastest for gaming but for running 5 wow instances I don't know. Maybe an AMD x6 chip would show a benefit with it having 6 cores.
Why?I multi-box World of Warcraft, I run five copies of the game simultaneously on one PC.
Why?
I've never played WoW, I'm just genuinely curious.
I suspect the Sandy Bridge will end up faster especially if you overclock it a bit.Oh I see, well from what I have learnt today. I'm thinking 2600k Sandybridge, Asus P8P67 DELUXE, Corsair Vengeance 12GB, Noctua NH-D14 Dual Radiator.
I have ummed and arred about the AMD because of the 6 core. But without anyway of really knowing if it would benefit it - i didn't want to take the risk.
