Anyone got it working on Win 7 x64?
Keeps crashing on launch![]()
Works fine for me on 64, but I do not play it as it will not run at my resolution.![]()
seta r_mode -1
seta r_aspectratio 2
seta r_customHeight 1200 //change this to match your height
seta r_customWidth 1920 //change this to match your width
seta r_fullscreen 1
	It will run at any resolution, if you use a autoexec file.
In your doom 3/base folder, create a text file named "autexec.cfg"
Put this text in it:
Code:seta r_mode -1 seta r_aspectratio 2 seta r_customHeight 1200 //change this to match your height seta r_customWidth 1920 //change this to match your width seta r_fullscreen 1
Then when you start up, it will load that resolution - the in-game menus won't display non-standard values so you'll have to start a game to see it is working correctly.
Tried this the other day with retail version and it didn't work for me. Tried it in config & console.
will enable AA as well? the settings dont stick if i remember right
I have retail and it works fine with win 7 64, I used some widescreen fix for modern resolution and it all runs just great. There is some wicked Doom1 mod for this game.
