Some of you may remember my thread some time ago where I asked your advice on building my super machine.
Well I have finally finished the build part of the project, so here it is.
First the Spec
Asus Rampage III Extreme Mobo
Intel i7 980x CPU
Corsair H70 Corsair Water-Cooler
2x AKASA Viper 120mm Fan
OCZ Platinum 12GB (3x4Gb) DDR3 PC3-12800C7 1600MHz Memory
XFX ATI Radeon HD 6870 Black Edition 1024MB Graphics Card
OCZ 240GB Revo SSD
Western Digital Caviar Black 2TB HD
Sony AD-7261S-0B SATA Writer
Corsair 850AX PSU
Corsair graphite 600t
Apple 27" LED Monitor
So onto the pics.
All the boxes
Asus Mobo installed.
Then Powersupply
The poo bit. The USB 3 socket on the case has to be plugged into a socket on the back of the mobo. Not very clean, but i routed the cable the best I could to keep it clean
Power cables routed through the lower case bracket, then brought back around close to where they are needed
plugged in both power connectors, just because they were there. You only really need 1 unless going for extreme overclocking (from what I have read)
Installed the optional chipset cooler. This is advised when you arent using a conventional CPU heatsink with fan as there will be no airflow across it.
H70 cooler fitted. After running the comp for the first time, I found the stock fans to be far too noisy so I replaced them with AKASA PWM Vipers which are much better. (not shown in pic)
Graphics card and my Revo SSD, and 12GB Ram installed. Hopefully in the correct slots. I couldnt figure out which mem slots were bank 1 so I googled pics of other builds and copied
Cable routing around the back of the mobo
and the final shot showing all components in place inc HD and DVDR
This is the first PC I have built in over 7 years.
I have to say things have come a long way since then. In my day, the latest innovation in computer building was ide cables that had been bundled into a single round cable.
I was amazed at how much easier it was to build this pc with the modular power supply and the amazingly well designed and laid out case. Love the no screws quick install drive bays.
The machine is up and running beautifully now.
Only 1 issue left to resolve which is, for some reason I cant work out, the mobo reports CPU fan failure even though the AKASA fans are plugged into the PWM CPUFAN header, and the bios has full control of the speed and even correctly displays the fan speed and adjusts the speed based on temps.
My next big hurdle is overclocking. I am a SERIOUS noob when it comes to overclocking. Last time I did that, I had to solder a resistor to the CPU cartridge or something lol. There are like 11 million settings on this board which I have no clue about. At the moment, I have used to boards eazy oc feature and clocked it to 4.2ghz and the machine runs perfectly with an idle temp of 36 degree going up to around 46 under use. I am sure I can go a lot further. I just selected the safe option in the bios
I could do with some serious help getting the best out of the machine. Particularly around the memory clocking and bus speeds. Any gurus wannna pop round for a play? Especially if you understand this mobo and its features
What I do know is.. this thing is snappy! apps all open instantly.
look forward to your comments.
First the Spec
Intel i7 980x CPU
OCZ 240GB Revo SSD
Corsair 850AX PSU
So onto the pics.
All the boxes
.jpg)
.jpg)
Then Powersupply
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
.jpg)
