CPU limited with a 3.5GHz Q6600 in a graphics benchmark? Really?
To the extent that I'm getting similar scores to a similarly-clocked GTX470 with the same CPU?
Yes....CPU limited with a 3.5GHz Q6600 in a graphics benchmark? Really?
Yes....
The i7 quads are much much faster for gaming..
Q6600 are about 4 years old now![]()
reviews say .. nope - hardly any difference at all - here is Crysis for example
http://www.bjorn3d.com/read.php?cID=1379&pageID=5565
i ran the benchmark to show its not just you at the same settings and got 50.8 average. now im running my card at 915 core so you would expect me to get nearly 580 performance. im running a phenom 2 at 3.6ghz. theres my problem.
I just did a quick test with my 580'si ran the benchmark to show its not just you at the same settings and got 50.8 average. now im running my card at 915 core so you would expect me to get nearly 580 performance. im running a phenom 2 at 3.6ghz. theres my problem.
thats why you should never put all your faith in benchmark sites, real world experience from normal users is far more valuable. they often just use a very small section of gameplay from every game, which does not give a good overall picture of the performance
I'm just guessing here, so don't have a go if it turns out to be silly, but could the resolution here be playing a part?
I often notice when reading graphics card reviews that at lower resolutions there is less difference between cards. The difference at 2560*1600 is usually more pronounced than at 1680*1050.
