Hi there,
My brothers car has a badly corroded front cross member. He's bought a replacement and I am going to strip the front off of the car shortly.
I believe the existing cross member is spot welded on.
I have a few questions as am unsure on a few bits.
Removing the spot welds? Use a spot weld drill bit? Basically a drill bit which is flat at the end.
How about welding on the replacement part. I have no welding experience or equipment. I cannot drive the car to a garage after stripping it down.
My thoughts are either find someone who can come to me to weld OR drill the welds out all of the way through and then bolt the new crossmember on?
Would this bolting method be advisable or safe?
What would you expect to pay for someone to come out and spot weld it on?
