Can Asrock P67 Extreme 6 or Fatal1ty owners please post your overclocks in here
Caporegime
27 Nov 2005
Guernsey
Can Asrock P67 Extreme 6 or Fatal1ty owners please post there overclocks in this thread so us asrock motherboard owners can compare what overclocks were getting out are motherboards..:)
Hoping there are some other asrock owners on here :p
Am up to 4800mhz so far with air cooling....Picture below is with all 4 cores loaded
5100mhz...............That will do for now,,so am going give up trying to get any higher before i blow my rig :p
Though your overclocks might be stable, the amount of vcore reported by axtu is kinda a lot?
I mean, my i7, which should have more vcore, only has 1.19 on 3.885ghz.
and the temps are a bit high if i judge from the cpu temp there, usually core temps tend to be higher by up to around 10C more.
asrock extreme 6 & i2500k
can get into windows with 52x102 @ 1.51vcore, but due to not knowing much about what is BAD in vcore I stick to 4.5ghz with 1.35v
What stats are other people seeing under 1.45v, but more likely closer too 1.4v ?
Yeah, you don't want to be running at 1.51v 24/7! It is safer to stick at 1.35v though you can probably get a bit more out of it and still be safe.
I don't think the Sandybridge chips are quite as fragile as people as people first thought but I personally when I get mine won't go above about 1.37v. Either that or the lowest taht gives me 4.6Mhz, I will be happy with that and don't see the need for more.
I mean, my i7, which should have more vcore, only has 1.19 on 3.885ghz.QUOTE]Don't worry that 5ghz & high vcore voltage is not my 24/7 overclock,
It just seeing what this asrock motherboard & i7 2600k CPU can do ;)
I normally keep my cpu at 4400mhz or 4600mhz for my 24/7 overclock
Temps are going be high with air cooling at 4800mhz plus high vcore voltage with 100% load on all 4 cores
Just a mini update, I'm now running 4.5ghz with 1.28vcore which seems much more reasonable. I'm using 96blck x 47 multiplier, instead of 45x100 or so.
My 2500k + Extreme6 setup is winging its way to me by Tuesday hopefully.
*puts himself down for membership*
I chose the Asrock due to the LGA775 compat so I can just drop it in and still use my water setup. I am hoping to be able to do 5ghz 24/7.
Am thinking of going back to watercooling and using my old D-TEK (socket 775) waterblock on this motherboard
Don't know if you be able to get 5ghz stable 24/7...
But at a guess i say you should be able to get 4800mhz stable 24/7
Doesnt stop me hoping :p
It's all about the voltage really, anything over 1.4volts is apprently too much for 24/7 and air is enough to keep 1.4volts and under in shape...
I'd like to have some confidence from others really, about maintaining a high voltage under water, as I'm sitting at 50 degrees or under on my water at load
If you got the guts to give it a high vcore 24/7 then you most likely get 5ghz stable
Am too chicken to try :D , plus i don't think my cpu air cooler would cope
Well I ran my e6600 with 1.6v (BIOS) which was ~1.55 real for 4 years+
If 1.4-1.5v (real) with the Sandyvag only gives me 3 - 5 years use that is good enough for me. If it pops sooner... well I'll buy a new one and run lower volts through it :p
