- 22 Jan 2008
- King's Lynn, Norfolk
Hi all
I've been out of the loop for a little while now, and I'm not really up to speed with the current tech and what works well with what. I'll have no problems putting the stuff together (hopefully
Total: £727.10
Just a couple of questions:
Will the triple-channel work in tri-channel mode on this motherboard with this RAM?
Will the PSU be sufficient for the setup I have posted?
Regarding cooling, will I be needing any other cooling for the case etc?
edit: I'll be using the system mainly for gaming. The monitor & TV I'll be using has a resolution of 1080p.
)- OEM Intel Core i7-2600K 3.40GHz (Sandybridge) Socket LGA1155 Processor - OEM £236.99
- OCZ Vertex 2E Bigfoot 120GB 3.5" SATA-II Solid State Hard Drive £179.99
- Gigabyte P67A-UD3 Intel P67 Chipset (Socket 1155) DDR3 Motherboard - (Sandybridge) £114.98
- XFX Pro 650W Core Edition Power Supply £68.99
- Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel (CMX6GX3M3A1600C9) £67.99
- Antec 100 One Hundred Ultimate Gaming Case - Black £43.99
- Samsung SH-S223C/BEBE 22x DVD±RW SATA ReWriter (Black) - OEM £13.19
- Intel Official i7/i5/i3 CPU Cooler (Socket 1155/1156) £0.98
Total: £727.10
