Hi,
Ive got a P5NE-SLI motherboard.
I moved down my 9500GT into the 2nd PCI-E slot and installed a GTX 480 into the primary slot. The machine booted and has deteced the GTX 480.
However, even though air is comming from the 9500GT in the 2nd PCI-E slot it wont work, also it does not appear in Device Manager.
I have re-seated the card and it is definatly is in correctly, plus air is comming from it.
I was looking at the manual for the board and it said multi monitor mode is enabled automatically if SLI mode is disabled. I have left the red SLI board in its default position so i pressume that means SLI mode is disabled.
Had a brief look in the BIOS but not really sure what to look for.
Any ideas whats wrong?
