Arctic Cooling Freezer Xtreme Rev.2 = a joke ?
19 Jul 2007
notts , uk
my brother wanted a new cooler for his phenom II 550 which did not sound like an hair dryer for £30 or under , so in the end he decided on the Arctic Cooling Freezer Xtreme Rev2 thinking it would manage him as he does not overclock i installed it for him replacing the mx2 which is already on it with mx4 which i ordered from ocuk at the same time . with hwmonitor running in the background he started to test it running a few games (halflife2 + bioshock etc) , after around 10 min he decided to check on the temps he was getting and was supprised it was hitting 65c (stock fan etc hit 62c max) . so my question is where do artic cooling get the 160w worth of cooling from ? , to me that figure is a joke for a cooler which does not cost much less than my akasa venom . his case is the cm storm scout , specs below taken from the product page at ocuk . can he return it with not being happy with it ?
- Heatsink: 130L x 100W x 131H mm
- Fan: 120mm x 1
- Fan speed: 800 -1500 RPM (Controlled by PWM)
- Air flow: 35.7CFM / 60.7 m3/h
- Maximum Cooling Capacity: 160 Watts
- Unmatched cooling performance – 160 Watts
- Unique twin tower 102-fin heat sink design
- Effective heat dissipation via 4 double-sided heatpipes
- 1 ultra quiet 120mm PWM fan
- Patented fan holder eliminates the buzzing sounds
- Voltage regulators and north bridge cooling
- Pre-applied MX-2
- 6 Years Warranty
reinstalled it 4 times and even running the fan at full speed changed nothing , i have also tested it on my 1090T which is hotter than his cpu . it hit 70c on my 1090T after 4 min of fc2 , my cpu never goes above 41c with the akasa venom with a push pull setup
Hi, my two sons are using ACF 7 V1 on a , Q6600-3.2GHz / Q9550-3.1GHz, have just ran WPrime-1024m-stability test using the Q6600-3.2GHz which took about 9 minutes to complete and it keeps your cores at 100%. After about 4 minutes the core temps reached 49:48:54:54'c, just before the test finshed the temps reached 49:49@55:54'c. So mormal use gaming ,etc should just be in there fortys using MX2 and the Q6600 heatsink has never been off in three years.
Something is not right if after 9 minutes my Q6600 reached 49:49@55:54'c with WPrime 1024m stability test and your brothers reached 65'c gaming 10 minutes. How much paste are you applying did you clean the heatsink + CPU properly before applying it, are all the heatsink locking pins down properly , is the fan reaching max:rpm?. You can't a compare the AC7 V2 £19 to the Venom £35, the extra £16 gets you a far better CPU cooler.
but i was asking why they state upto 160w cooling when it cannot cope , i even put a viper fan infront of it at full speed (83 cfm) and it made little differance and yes the fan on the cooler was at full speed
For £30 you could have got a Freezer 13. But I bought 2 (both from here) and they both came with a broken fan. Dissapointment Arctic Cooling, dissapointment.
That review is of a freezer 13 m8.
The OP is talking about the freezer Xtreme.
I'd say its faulty to be honest.
The freezer 7 or freezer 13 is better but the temps should definitely better the stock cooler if it's been fitted correctly.
yes it was fitted correctly as i made sure it was , although it was a pain to get the clips on the amd fittings as my hands seemed to big lol . when i tested the cooler at max speed on my mobo it reached a max speed of 1308 rpm , it says max fan speed should be 1500rpm
yeah but the freezer 13 is better than the extreme and even that isn't very good according to any review i have seen :(
arctic cooling are living on good memories from the original freezer 7 and freezer 64 which were top budget coolers but others have caught and surpassed arctic cooling in the budget sector now.
