Catalyst Driver install properly?
  • Thread starter Thread starter Kyo
  • Start date Start date
Kyo
Kyo
11 Oct 2003
Hi
Finally thought i would upgrade my trusty 10.7 cats to the latest 11.1 gfx drivers for my 4980.
Uninstalled and then install 11.1 direct from amd site. Just checked the software info
Driver Packaging Version 8.812-110104a-111988C-ATI
Catalyst Version 10.6
Provider ATI Technologies Inc.
2D Driver Version 8.01.01.1114
2D Driver File Path /REGISTRY/MACHINE/SYSTEM/ControlSet001/Control/CLASS/{4D36E968-E325-11CE-BFC1-08002BE10318}/0000
Direct3D Version 7.14.10.0806
OpenGL Version 6.14.10.10428
Catalyst Control Center Version 2011.0104.2155.39304
Does this look correct? Catalyst says it 10.6 now? should it not be 11.1? Have no idea if the d3d and opengl drivers has been updated as well?
Cheers
Here is mine on 11.1a I believe.
Driver Packaging Version 8.82.2-110112a-111972E-ATI
Catalyst Version 10.12
2D Driver Version 8.01.01.1123
Direct3D Version 7.14.10.0812
OpenGL Version 6.14.10.10516
Catalyst Control Center Version 2011.0112.2221.40058
I think something has gone wrong :(
I got the driver straight from the amd home site :confused: The only thing i can think of is i didnt go for the full suite i opted for the slightly smaller package, the one without APP and OpenCL driver -as i had no clue what that was?.
Do you think i should redownload the full one with APP and OpenCL to make a difference? Or perhaps a try a different source like Guru3d?
Download the full package and uninstalled the current via ati install manager.
Rebooted and installed the new install from Guru3d and the software info is exactly the same :confused:
Can you please tell me where you got this version of the driver. I think the ones i downloaded although are offical arent as up to date as the ones you are using?
Don't worry it has installed correctly. It is a bug in the 11.1 package that will show an older install of the catalyst version number but it will have installed the latest version. I have installed 11.1 but it shows up as 10.11 but i know it is 11.1.
heres mine and it is different again:confused:mine dosn't have the catalyst version listed as anything like the above.
Driver Packaging Version 8.82.2-110119a-112250E-ATI
Catalyst Control Center Version 2011.0119.1312.23596
hmmmm mine is same but with Direct3D Version 7.14.10.0806
did you have another version installed before or was this a clean Windows install ?
