Great post.I didn't really like the first one so I doubt I will bother with this but thanks anyway
Stoner81.
Finally have my Logitech Force EX working perfectly. Only thing is, it feels like I have such an advantage over most other people who seem to have pads. The level of control is so much better.
Getting what feels like microstutter - certainly doesn't feel smooth, and yet my fps are 40+
Graphically it isn't great though.
Are your brakes either on or off?Care to share what you did, my G25 is a lifeless piece of plastic right now.
Aye aswell as the clutch, really slow steering, despite what i do with the ingame sliders - how did this ever pass beta ill never know.
HI Gareth170...I have check this for you later as i only been using the default xbox controller profiledoes it have fully customisable controls?? e.g being able to have the driving controls all on the right analog stick of the xbox360 controller
Why is it that this game runs on the same console hardware as the 2006 original... yet the PC system requirements appear to have shot up in that time. TDU 1 runs great on what is nowadays modest hardware (mine for example) but TDU 2 is more demanding?
I haven't got the game but the graphics don't look to have improved at all, in fact they are possibly worse.
That's fairly standard for new generation console games; back in 2006 the XB360 was extremely new and the developers perhaps hadn't had time to fully get to grip with optimising games for the platform. This often happens and for example if you compare early Saturn games with ones that came much later there is a marked difference in quality. 4 years on and obviously the developer will be right on the money in terms of XB360 efficiency.
Also when it comes to PC system requirements don't forget the PC version didn't come out until 2007, then just the simple fact that system requirements aren't worth the paper/pixels they are printed on. They will ALWAYS go up over time simply irrespective of technical reasons because the average computer has got faster; system requirements are not dictated solely by how demanding the game is, but also by what the publisher thinks they can get away with. Even games that use the same engine often have requirements creep if the sequel comes out a significant amount of time later.
Or in other words, the system requirements for TDU2 are actually what the requirements for TDU should have been, just they wouldn't have been able to get away with it in 2007. 2.2ghz C2D/X2, 2GB RAM, 8800/3870. Sounds pretty much bang on for TDU to me, yet that's the TDU2 spec. Good luck trying to get good performance out of TDU from a P4 2.4, 1GB RAM and a 6600GT.
Anyone elses TDU2 only displays in window mode ??
I can't find an option to change it to full screen![]()
Try alt+enter
^ they redid Oahu over as well, as for the casino I believe there's a map on the first page
thanks mateHI Gareth170...I have check this for you later as i only been using the default xbox controller profile
If it hasn't then you need to make another customisable controls thread![]()
Yes gareth you can customise the controls so you can set left/right/forwards/backwards to the Xbox360 joystickthanks mate
