- 25 Jan 2011
- Solihull, Birmingham
Ok, hey guys, this may end up as a bit of an essay, for the past month now i have been trying to work out why my pc has so much problem posting, 99% of the time nothing happens, not even a post check, here are the steps i have taken so far.
Parts all out of case on a non conductive and static free surface -
Motherboard (Crosshair III 790FX RoG)
CPU - AMD Phenom II x6 1055t
PSU - OCZ Stealthstream 600watt
RAM - Corsair XMS3 4GB 1600mhz
I try to power on system with this setup, CPU fan comes to life, hard drive light on mobo flashes, RoG icon on mobo is lit up and psu is active with fan spinning, LCD poster simply says "welcome" for a few seconds then starts to display the unconfigured Cmos time starting from 00.00.00
I try this again with just one stick of ram, same thing happens, then i try again with no ram at all, expecting a pc beep and a warning from poster, the same thing happens again - this leads me to believe that its not my ram that is dysfunctional as it is not even trying to detect it in the post
I know for a fact that this mobo will post happily if all the "power leds" on mobo are lit, there are about 4 as far as i can remember, which light up green by key component areas, RAM, CPU, NB, SB etc, but at the moment no lights are displaying.
I first thought when i got this problem it was a lack of power, my Radeon 6970 could have been hogging it all, but even without card still nothing, and card is tested and working in another system.
The problem is i cannot test my other components as i dont have anything of their level to swap out with, My cpu i am pretty confident is perfectly ok, video card is fine, ram - im not too sure about as i have had some problems with it (lcd poster - DET DRAM) - sticking at this stage of post)
The power supply, according to all psu calculators is more than enough for this system and is reliable and works with other systems i have tried
This, to me, points at the problem being the motherboard - somehow it isn't recieving the power it requires to start posting, why? i don't know but i would be very greatful if anyone could help me shed some light on this and offer their opinions, TIA,
Jamie
Jamie
