HD 5850 temps
9 Jan 2011
Hi everyone,
I have just been trying to overclock my new MSI ATI Radeon HD 5850 Twin FrozR II 1024MB with MSI afterburner with Kombuster running to test the stability. I was wondering what you though of these temperatures.
Running kombuster stability test for 15 minutes with post-processing and xtreme burning mode on 1280x1024 with my gpu at 850 core/ 1200 mem, it hovered around the 68 degrees mark with the fans running at around 70%.
The temps seem ok to me but i don't know much about graphics cards really.
Do you think i could change the fan settings to a bit lower, as they make a hell of a noise over 60%?
cheers.
spec if you need them
Phenom ii x4 965 be
Asus m4a88td-v evo mobo
MSI ATI Radeon HD 5850 Twin FrozR II 1024MB GDDR5 PCI-Express Graphics Card
samsung spinpoint f3 1tb
4gb corsair xms3 ram
antec truepower new modular 650w psu
cooler master elite 430 windowed case
windows 7 ultimate
didn't mean to post specs, meant to edit but pressed wrong button.
850 core / 1200 mem is just short of 5870 performance. Think it takes 925 / 1200 to match it.
Kombuster will heat up the gfx card a fair bit more than gaming will, so your temps are fine.
thank you for the respones.
now i just need to get afterburner to remember profiles and setting etc.
it seems to only apply when it wants to. also, i am trying to set up 2d/3d profile but can't seem to get it to stick. do any other programs affect the settings at all? ccc maybe, should i disable something in that, or delete it all together?
Or is afterburner just very tempremental?
cheers
am i doing something wrong in afterburner?
when i click apply it reverts to the original setting, also, i can't set 2d/3d profiles, they won't change.
cheers
yes mate.
i click on profile 1, it says that it has loaded, but when i click apply, it doesn't apply, all of the sliders go back to default.
Delete the 2 or so profiles you have. Close afterburner & then load it again.
Set the clocks, etc... click apply, then save to a profile slot.
Make sure the clock & fan control in CCC Overdrive are disabled.
yea, that seems to have worked, thanks.
it still doesn't seem to be using 2d/3d though.
Oh, no it hasn't. after restarting afterburner, it still will not apply changes.
having just overclocked my 5850, this is my heaven score, do you think this is alright?
FPS:
32.0
Scores:
805
Min FPS:
12.4
Max FPS:
64.0
Hardware
Binary:
Windows 32bit Visual C++ 1500 Release May 21 2010
Operating system:
Windows 7 (build 7600) 64bit
CPU model:
AMD Phenom(tm) II X4 965 Processor
CPU flags:
3415MHz MMX+ 3DNow!+ SSE SSE2 SSE3 SSE4A HTT
GPU model:
ATI Radeon HD 5800 Series 8.812.0.0 1024Mb
Settings
Render:
direct3d11
Mode:
1400x1050 4xAA fullscreen
Shaders:
high
Textures:
high
Filter:
trilinear
Anisotropy:
4x
Occlusion:
enabled
Refraction:
enabled
Volumetric:
enabled
Replication: disabled
Tessellation:
normal
temp never went above 55.
another question, is just completing heaven meaning that the card is stable?
also, as i can't ge afterburner to change 2d/3d settings, is it alright to just leave it all on the oc'd settings all the time?
thanks.
Looks fine. Completing Heaven is a step towards meaning its stable but you can get overclocks that work fine in one app & cause a problem in another.
Best thing to do is play the games you normally would. If you get any unexpected freezes, driver stops responding, blue screen, etc... lower the memory & core clock by 10mhz & try again.
Or increase the voltage by 0.025v if you're not too high already. Think 1.25v is regarded as a safe'ish level on 5850's as long as your load temp isn't too high ( 80+ )
As for the afterburner problem, remove the profiles from the 2d/3d option popups. Close it down & restart it again then add the profiles back into the popups.
If that doesn't work, try a reboot after closing afterburner down then restart it, etc...
