560Ti - PSU sufficient?
7 Feb 2011
I'm looking to upgrade my GFX card. My current PSU is a Coolermaster Real Power M520. Will this be sufficient for a 560Ti? If not, what would you recommend as a good economical modular PSU for someone on a budget?
am running an evga 560ti
spec of the card Core Clock Speed 850MHz Processing Cores 384 Memory Clock Speed 4104MHz
Memory Bandwidth 131.3GB/sec Shader Clock Speed 1700MHz
and am running a q9550 oc 3.70 and water cooled
shud be cool cool, for sli future though id go at least 750, xfx black edition is good and cheap.
For the benefit of anyone reading and wondering, I got my 560Ti OC installed yesterday and it's running fine. I had no problems even while standing outside the Stormwind AH in World of Warcraft with all settings cranked to maximum, and the system temp didn't even rise. (Not that I got 60fps - I averaged 34 - but still.)
I plan to run a couple more tests using Borderlands and Rift to make sure it's happy under load, but if a 520W supply can cope with a 560Ti on my system - which has three HDDs, an SSD, a DVD-RW and two 300mm fans to cope with - then it should suffice for most other systems as well.
my psu 500watt peek power 550
so fan 9 fans 3 hdds high clocked q9550, 560ti and water cooling
