Today Only, we have 25 units of OCZ Vertex 2E 120GB 2.5" SATA-II Solid State Hard Drive for only £167.99 inc. VAT. Vertex 2 not only provides a faster, more responsive PC experience, but promotes cooler, quieter, and more energy efficient conditions compared to traditional mechanical hard drives.
We also have 49 units of OCZ Platinum 4GB 1600MHz DDR3 Memory for just £25.99. Configured for dual channel mode, these ultra-compatible 4GB kits ensure optimal performance with an ideal combination of improved lower power requirements, high speeds, and latencies.
OCZ Vertex 2E 120GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-2VTXE120G) @ £167.99 inc VAT
Based on a cutting-edge new architecture, Vertex 2 Solid State Drives raise the bar once again and deliver unprecedented performance for the complete gamut of gaming and professional multimedia applications. OCZ designed the Vertex 2 to surpass the competition where it counts most, pushing the limits in both sequential and random read/write rates. With spectacular performance in 4k file writes up to 50,000 IOPS, these latest drives take productivity to the next level with over ten times the performance of the previous generation. Using the latest controller technology, Vertex 2 not only provides a faster, more responsive PC experience, but promotes cooler, quieter, and more energy efficient conditions compared to traditional mechanical hard drives. OCZ Vertex 2 SSDs come backed by a 3-year warranty and 2 million hour MTBF for ultimate peace of mind.
- Capacity: 120GB
- Controller: SandForce SF-1200
- Maximum Read: 285MB/sec
- Maximum Write: 275MB/sec
- Sustained Write: 250MB/sec
- Max I/O Per Second (IOPS): 50000 IOPS (4KB File)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-II
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Only £167.99 inc VAT.
ORDER NOW
OCZ Platinum 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Ultra Low Voltage Dual Channel Kit (OCZ3P1600C9ELV4GK) @ £25.99 inc VAT
OCZ Extreme Low Voltage (ELV) DDR3 kits are designed specifically for the Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for dual channel mode, these ultra-compatible 4GB kits ensure optimal performance with an ideal combination of improved lower power requirements, high speeds, and latencies.
Developed for enthusiast platforms that are becoming increasingly more power-efficient, OCZ ELV Dual Channel solutions are the choice counterparts for leading-edge performance, allowing high-speed memory to function farther below the upper voltage thresholds of Core i3 and i5 CPUs, operating at a blazing 1600MHz CAS 9 requiring only 1.35 Volts. OCZ ELV memory helps lower internal case temperatures along with your utility charges as less power is required for high frequency DDR3, offering incredible stability at stock speeds along with substantial overclocking potential.
Developed for enthusiasts and gamers making use of the latest technologies, OCZ ELV modules were engineered with the same affordability and performance standards as the Lynnfield platform. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ DDR3 kits are the perfect complement for the P55 Chipset and choice CPU to deliver the maximum stability. Together, P55 and OCZ memory are the ideal dual channel option for cutting-edge desktops.
OCZ DDR3 ELV Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
Specification:-
- Sandybridge compatible
- 1600MHz DDR3
- CL 9-9-9-24 (CAS-TRCD-TRP-TRAS)
- Available in 4GB optimized kits
- Unbuffered
- Platinum Layered Z3 XTC Heatspreader
- Lifetime Warranty
- 1.35 Volts
- 240 Pin DIMM
Only £25.99 inc VAT.
ORDER NOW
- Capacity: 120GB
- Warranty: 3 Years
ORDER NOW
Specification:-
- 1600MHz DDR3
- Unbuffered
- Lifetime Warranty
- 1.35 Volts
- 240 Pin DIMM
ORDER NOW
