Could you post a pic of the inside of your case? I just bought one and I'm looking at how big they are on the side and also, whats the difference between the Lite and the Advanced versions?
Not the best pic in the world, CoolIT Eco 240 dual radiator at the top, gpu is a GTX470, i removed the bottom drive cage as i dont have that many hdds.
They are alright, was surprised that they are pretty roomy inside, to get push pull with dual radiator i had to put the fans in the cavity above the case under the mesh i guess its built that way so you can do it.
