please help
21 Jan 2010
Wales
So got my shiny newstuff today
XFX 6970
and Corsair 750w psu
I have it all pluged wired correctly yet...
when i fire her up the fans start up and stay at a lazy pace :confused:
nothing else happens
i do suspect it is a 4pin conector on the mobo :o
(it has nothing plugged into it)
but im new at this and have no idea...
help me guys please
guess i have got the wrong psu perhaps there is an adapter if this is the case
im upgrading a "world" pc so not really sure
it is an ipowerX3.0 pakard bell
the Corsair HX750w has an 8pin
so yer my bad... :(
is thereno adapter i can buy or am i stuffed now
If is a new corsair 750W it should have a CPU 4+4 connector which is an 8 pin block which can make 2 number 4 pin blocks by splitting it.
andy.
Hahahaha :D
yer spot the new guy
err mods delete post ;-)
thank you for your wisdom i dunno how i did not spot this
lol
everyone makes mistakes, especially with your own builds as you are soo excited on getting it running you miss the obvious. many a time i have forgott to plug in a cable for something coz i was in such a rush to get it working. we live and learn.
Well Fuuu just noticed the gpu does not come with a hdmi cable
guess i better run down the shop now lol
Oh and it stil wont switch on properly
infact its not doing nothing at all now
not even a lazy fan whirl
95% sure its all wired corect now
Any other obvious mistakes you can think off guys ??
brb 20 mins
sorry if im missing something blindingly obvious, but was the system working correctly before the upgrades, or is this a complete new build?
Mate, you don't need a HDMI cable to connect to your monitor.
Use the DVI or VGA cable that you had before.
DVI has a white connector, VGA is blue.
was there no dvi-vga adaptor in the box, would be suprised if there wasnt.
so am i right in thinking system is as is, but with a new psu and gfx card?
no the XFX 6970 came with nothing but the gpu and driver disk - bridge
just got back with dvi - vga adapter
im going totake it all out again start fresh
then if nothing is better
/cry
Take everything out of the case and build it on a desk. Connect the old PSU (assuming you have it still and its working) and try booting with your old graphics card/onboard gpu.
If it all works then connect up the new PSU first (and not the 6970).
Maybe post up a decent quality picture so we can check wiring etc.
Most common fail is wiring up the front panel connectors as they can be quite tricky (if you've messed around with these).
Also ensure the CPU HSF is connected, some mobo have a fail safe/protection mechanism to stop booting if the CPU_Fan header is not connected.
Make sure the switch on the PSU is flicked to 230V &...finally check its switched on at the mains.
ok so here is the deal...
I have been here for a while now wires every where stressing
swearing been to the shop twice now for diffrent "bits"
taxi fare got drenched in rain and still no luck...
I come home from getting the dvi to vga adapter take everything out
check it all over w/e
suddenly i notice i had the old psu cable pluged in to the corsair
that cable was not pluged into a mains socket .
i expect lols a load
needless to say put it all back together now and its working a charm
Thank you and ave a good evening!
