I can't get good grades.
FP1? Is that what used to be called P4?
Ahh the good oldd days when Pure maths was pure and you had to skip whole sections of the book to finish in time for the exam...:p
Makes me feel old having done P1, P2, P3, M1, M2 and S1. It is a good idea them changing the P1,2 and 3 to 4 seperate modules though. There really wasn't enough time to actually learn each module in time once they added the AS exam.
M2 is really easy, but then I also did physics so covered it twice essentially. Pure after P1 was a *******.:(
I think it would be the same module as 'p4', but the specification is all different now. I think fairly recently the board jiggled around all the Further Pure modules so the topics are in different modules now. FP1 is now definitely an AS standard module (that you can do with knowledge of only C(Core)1 and C2 (the AS ordinary maths modules)), and FP2/3 are A2 modules, which require knowledge of C3 and C4.
I think they have also changed the module requirements since your day as well - now, for ordinary maths we do C1,2,3,4, and two options (I did S1 and M1), so its probably completely different to when you did it.
I am doing the mechanics option in physics as well, so I'll probably get some overlap at some points with the M2/3 and physics :).
I am doing a levels as well .
For maths just start about 2 months before the exam and do past papers, worked fine for C1 seemed like I only dropped 3 marks
Now for physics it is a bit harder, doing the calculations is the easiest part but learning definitions is another story. Make sure you know the definitions really well and keep reciting them, as well as doing past papers on top.
Draw a picture!
I don't care how simple the problem is, draw a picture of how you think you see the problem. Even if it's as simple as y=mx+c draw the picture. Even if it's a coordinate question and you think you know it, draw a picture! Even if it's the most difficult problem you'll ever come across, draw a picture of how you think you see the problem!
You'll soon realise your problems will get much easier.
I love my subject, you can get massive marks for just drawing a sequence of diagrams with some annotation. In fact a lot of lecturers specifically say they love them and would rather no essays at all. :D
My day. :( It was only 2003... :p
We were the last year to do Pure before they changed the system, although I thought they still kept P4,5 and 6 as that (so essentially we did core 1-4 and two other modules). The further maths was then any 3 (had to be one one pure I think) that you hadn't done. So to get an AS at maths and further maths you had to do any 6 modules, with 2 pure modules and one other compulsary for the standard maths. A2 was then all the others left (if taking A2 standard and further maths).
So essentially for the entire A level qualification you drop one whole module over those that took it before you. Not a bad thing as I said though as the ntroduction of AS exams meant it was almost impossible to fit all the modules in over 2 years, which is why they changed it.
The worst thing is that I don't know where I'm going wrong, I know the stuff but I just muck up the exam.
This may be a touch brutal, but if you can't pass the exams why do you believe you know the material? There's a world of difference between reading something and thinking "sure, that makes sense" and actually answering problems based on it. Either you don't know the material and therefore can't do the questions, or you do know the material but panic in exams. The former is readily fixed by doing many, many boring questions (without notes). The latter is fixed by manning up / dropping out / claiming dyslexia and getting extra time.
Law is just one rather large memory test. :p:p
Hiss :(
It's quite possible to know all the material and still fail the exam. GCSEs and A Levels are 20% knowledge, 80% exam technique.
flibbage0, you can get ahead by improving your exam technique. My motto has always been: Don't revise more, revise more efficiently. Here are just a few ways you can do that:
1. Print off all the relevant course specifications from the exam board websites. In most cases they will tell you exactly what you are and are not expected to know; read through them, make notes, know what to expect. Most of my fellow students didn't know what a course specification was at the time they were taking their final A Level exams.
2. Know the exam procedure inside-out. You would be amazed at how many people I encountered who enter A Level exams without a clue how the exam is set out; how many parts there are, how many questions you must answer from each, how many marks each question is worth, etc. Countless people lose significant chunks of marks by spending too much time on the first section, not realising there is a final section on the back of the questions booklet until five minutes before the end, etc.
This is an especially useful tip for getting ahead in cases where the exam procedure for your course has changed in recent years; many will presume the procedure is the same as for past papers.
3. Structure your answers, know the facts. As you have probably surmised from reading mark schemes for past papers, most exams (especially for science-based subjects) are marked by looking for specific keywords, phrases or facts.
Learn these, they will make you more efficient in the exam. Litter your answers with what the examiners want to hear, avoid unnecessary waffle that costs you time and marks. I have friends at university from private schools who were coached to write bullet-point answers for entire exam papers; you might stand to lose the usual 2-3 marks for good sentence structure, but your answers will be far more refined and you will spend much less time on each question.
4. Look for duplicate questions in past papers. Collate all the past papers for each of your courses, group questions by section as specified by the course specification. Many sections of each course will be so small, and the knowledge expected so narrow, that the same questions keep cropping up year on year.
The easiest question is the one you've already seen, reviewed the mark scheme for, and know exactly how it is marked. Many questions, especially those that are designed to delineate candidates at the highest levels, are designed to trip you up; be prepared.
5. Read the examiner's reports. Examiner's reports will tell you where your fellow students tend to trip up in exams. They will tell you the sections which students found most difficult (dedicate more time to revising these), the most common mistakes students make (ensure you don't make the same mistakes), and they may give hints as to the emphasis that will be placed on different questions in future (i.e. your) exams.
Some examiner's have a sense of humour too; at A Levels they often throw in the odd sarcastic remark. It's much worse at degree level!
6. Work out your expected UMS scores. Know how many 'real' marks you need on a paper; this often differs substantially from the UMS marks you need. Look for patterns in UMS conversion tables (usually available in examiner's reports), i.e. "65 real marks usually equals 80 UMS marks", draw up a spreadsheet for each of your courses with all your AS Level UMS marks and expected A2 marks.
Again, most of your fellow students wouldn't know what a UMS was if it slapped them in the face.
Those are just a few tips off the top of my head.
Let's just say they worked for me, and I hope they work for you too! :D
Chemistry Maths + Physics are the hardest A levels you can take.
I failed hard at maths, and only got a D in chemistry, but picked up a C in biology and geography and still got into a nice university.
I preferred my university which was full of nice people instead of straight A snobs with their heads stuck up their own arses!
Oh, I did absolutely no homework and very little revision. 6 Bs + 2 Cs at GCSE, CCD at A level, and I passed everything at Uni leaving all my work till the last minute, but dropped my dissertation because it was pointless combined with my 2.2 average and settled with an ordinary degree.
Yea, if I actually had revised and worked hard, that might have helped.
