Amd cpu temp?
22 Oct 2010
Pontefract
i have a new water loop on my AMD phenom x 2 560BE and the temps was 29c idle it o now idling at 14c, is there a problem with my temp monitoring program? or can it real be that low?
i am using Core Temp 0.99.8
Unless your room temp is 14 degrees or lower, I'd say theres a temp monitoring issue.
Water cooling can have great effects don't be surprised.
Even under water at normal room temperature it wouldn't be as low as this, unless its outside in a garage or a very cold room. What is the temperature in the BIOS? Perhaps try another temperature monitoring programme like Open HWMontior. Is is at stock speed also?
Yes i reset it to stock as i will removing it tonight as i want s new CPU.
Open HWMontior is showing the same temps.
that is probably only a few degrees over ambient temp (unless your house is freezing :)) so it's probably right, what are the load temps like ?
i haven't run any i am removing the CPU tonight to post to HeX, and i have a phenom II X4 955 coming soon witch i will clock a little and test
my phenom 2 555 runs at the same sort of temps, 29C idle and 55C load with stock cooler its overclocked to 3.8ghz. These temps are when all 4 cores are not unlocked
