Home and tired.
2 Mar 2009
London
...but, felt relieved and refreshed when I saw these after I open the door. :p
Here's the rest and ready for tomorrow.
Will be building this tomorrow and I will be posting pic as as I go along. ;)
I hate OcUK for these "Weekly Deals" and "Today only" deals.:rolleyes:
Dont forget good quality pictures as you go for a build log, so people on these forums can learn things like,
graphics card clearance in the case.
ram height.
cable tidiness.
Hmm, with the Antec 1200 case you can't have any graphics card clearance as the case only supports SLI and just barely. Unless I'm doing something stupidly wrong, but I am not blind I can see where to fit cards, then the Antec 1200 case isn't the best for putting 2 jumbo sized graphics cards in.
Then again, suppose it depends on the MOBO, with the X58A-UD7, this is the case. No pun intended.
As promised, here's some pics of the build.
GPU sits right on top of the Marvel sata 6 ports. At the moment. i'm using both intel sata 6 ports. One for SSD and one for HDD. If I need to add another drive later on, that would require taking off the GPU first.
Antec 1200 maybe good for air cooling. The obvious issue is, you can'not instal a mechanical hard drive opposite to newer or latest GPU leaving you with only the top HDD and lowest HDD cage.
As to cable management, there's plenty of room behind the mobo and cage tray to tucked in the wires, but, I found these stuff makes it a bit more easier. Wished OcUK will stock them.
So far, everything's been looking good and i've settled for this.
That's all folks and thanks for viewing.
