Good PSU for my needs?
29 Dec 2010
So after a bit of contemplation, I'm going to leave my 550w PSU in the home computers, because its warranty is finished and I don't want anything to happen with the PSU that was in it. So, I need a new one, which would you guys recommend? It needs to run a 2500K, 2 sticks of RAM, the usual HDD and optical drive, and have room left for a nice graphics card. I'm currently using the gtx 460, but I think in future I will upgrade to a better card when the current one becomes outdated, or put in another 460 for SLI, so there must be room for them. It kinda needs to be a decent price, as I'm on a budget. Say, max 55-60 quid? Thanks :D
Yes they are, but just more expensive, and modular if you select a HX/AX, they also tend to be made by Seasonic, the same OEM that makes the XFX and Antec new truepower range.
The Corsair lines are good, some of there psu are made by the same manufacturer, but they are dearer. I have owned several Corsair units and got no complaints with them.
Just drunk and messing around, you should see the mess I have left in general discussion tonight.
