Cooking with LPG bottle/cylinder safety?
18 Oct 2002
Kuala Lumpur, Malaysia
Just have a couple of questions regarding cooking with and storing LPG bottles/cylinders as I've never had to use them before and its all new to me , only ever had electric / induction hobs before, and when they were gas it was piped and not from bottles.
We have a 2 bottles of LPG under the stove which connects with a rubber hose to the cooker , and one bottle is a spare. Seems to be common practise here so I'm guessing this is fairly safe.
Everywhere I've searched says to keep them in a cool place/outside which isn't really possible as needs to be connected to the stove and it gets a little bit warm inside - does this actually make it risky at all? I see big trucks filled with the things driving around in the sunlight all day so they must be able to withstand a fair amount of heat before anything goes wrong ?
Also should the regulator be turned off at all times other than when in use/cooking?
Thanks in advance !
All cylinders should be stored outside in a cage made for the purpose!
I always turn off the regulator when not in use. Less chance of a leak developing. I use them all the time camping. Gas cylinders can withstand a lot of heat, but should still be stored safely. Don;t forget that the vans are also driving around and the air keeps them cooler.
I did find a few UK websites that state they should be stored outside in a cage etc. I guess the regulations in Malaysia are a little bit more relaxed, a lot of even new condo developments don't have piped gas and no facility to store outside, especially whilst connected
Missed the location tbh :D.
I imagine it would be fine though. Unless there is a fire! I would still turn the gas off via the bottle when not in use though.
Well if there's a fire I'll be in trouble either way :D Just not used to having two big bottles filled with flammable liquid in the house !
Also a cheap way of cooking, 15kg of LPG costs only £5.50 !
