- 12 Feb 2011
Hey, I've just signed up to the forums as I'm in search of a little advice about a build I'm thinking of ordering and putting together.
I have a budget of £600 and the sole purpose of this computer will be for gaming. Currently I have absolutely nothing towards this, however, meaning I need to include a monitor, mouse, keyboard etc.. in the build - basically the works.
I don't need or want this computer to be upgradable after I've built it, though, I just want it to be a totally stand-alone machine with all parts complimenting one another, and no single part outshining the rest significantly.
I'm also after as barebones a build as possible - so I'm not including a disc drive and I'll be looking at getting a Micro ATX case - if airflow is suitable. Like I said above, this is only going to be a gaming machine, and as simple as possible: 1 hdd, no disc drive, small form case.
Anyway, if you're still with me, thanks, and here is what I have lined up so far:
Mobo: ASUS M4A78LT-M LE AMD 760G Socket AM3 MATX Motherboard - £42
CPU: AMD Athlon II X3 450 3.2GHz - £58
Graphics: MSI GTX 460 Cyclone OC Edition 1GB GDDR5 - £135
RAM: Corsair 4GB (2x2GB) DDR3 1333MHz XMS3 CL9 - £35
PSU: Corsair 500W CX PSU (2xPCI-E) – £48
HDD: Samsung Spinpoint F3 1TB 7200rpm 32MB Cache - £40
Case: Casecom MA-1199 Shiny Black MATX Tower Case - £18
Case Fans: 2 x 92mm Black Case Fan - £3
Monitor: LG W2361V-PF 23” LCD 1920 x 1080 2ms - £160
Keyboard: Microsoft Wired Keyboard 600 - £10
Mouse: Logitech MX 518 - £20
Network: Tenda Wireless-N300 PCI Adapter - £12
Total = £581
I've done a fair amount of research into each part and I believe they are all going to be at roughly the same level - except perhaps the GFX card and monitor - but I'm happy to spend a bit more on those bits as they will be the most important parts for a decent gaming experience. And as far as I'm aware the GTX 460 is a very good card, but won't be wasted with the CPU, Mobo and RAM I've selected. To get a more expensive monitor and GFX card I'm willing to skimp a little on things like the case, case fans, keyboard - as I think the ones I have chosen will be 'good enough' for the job. Also, as I'm putting very little inside the case, I'm hoping that even this cheap one will afford me enough air flow for the components (along with the two 92mm fans: one front, one back).
My biggest points of contention so far have been the PSU: whether it would power the GTX 460 and its two PCI-E requirements - I *think* it will after a lot of reading - especially as the lack of disc drive and single HDD will make the total built less power hungry; and also the keyboard, believe it or not, I want something that's nice to use, not just a plasticky piece of crap. I'm used to using a MacBook Pro keyboard and I really like how it feels, but I also want something that'll perhaps be a little more rugged for gaming - but it has to have shallow keys, not large-throw ones, which I hate!
One last thing, I'm not going to overclock this, I think it'll be powerful enough for my gaming needs at stock values, and I'd prefer to keep it clocked at stock so things don't overheat if the case air flow isn't phenomenal.
Any feedback on the components I've selected, or questions, or pointers would be very much apprecitated - thanks for your time!
Total = £581
