Hi i brought one of them pc dusters (tin of air) and used it to dust my pc
Once i had finished i pluged it all back in but my pc was going realy slow on start up and wouldent shut down would just freeze on shutting down window so had to press button in untill it turned off
i reinstalled windows from fresh and it seemed to be working better untill i install my gfx card now getting same problem as when i first pluged in from dusting pc is there anyway to check if my gfx is broken without taking it out and putting into another pc ? i only have a laptop other then the pc my card is in ?
card is under a year old am i covered ?
