- 11 Jan 2011
Hi, how many hdd can be put in raid0?
Is it a maximum of 2?
Thanks
Thanks
...but given that the chance of a disk failing is relatively small, I'm not sure the worry of RAID0 being unsafe is altogether rational. If you are storing anything important, you'll have it backed up elsewhere...Failure is n times more likely for n disks than running single disks alone, as a single failure leads to total data loss.
that writes are much slower due to the overhead of calculating parity.
So I could put 4 Samsung F3 in raid0 and would the read and write speeds be 4x the single drive?
Not exactly four times. Sustained read ought to increase by around 4. Burst speeds go off the chart but they're not particularly useful. Random access stays similar iirc. could be wrong.
are burst rates meant to go up ? my single caviar black has higher burst rates than my 2 250gb wd re drives in raid 0
Post 15 looks like a huge, wide screen res
Post 15 looks like a huge, wide screen res![]()
