Best Method To Clean H70 Radiator ?
30 Dec 2010
Cloud 9
Hi guys
Does anyone know how to clean the radiator on the H70 cooler and how often you would do this ?
Many thanks.
A can of air you can buy it for about £5 i use it on my pc when the dust get`s a bit mad.
the H70 is a sealed unit, it cant be cleaned.
well, you can take it apart but its a pig to bleed all the air out of it. need to fully submerge the rad in a bucket of coolant. i did this on an H50 to change the hoses to clear.
Wow mate dont think i would want to mess about doing that. I guess the can of air would do an "ok" job ?
I think people have interpreted cleaning in two different ways
Do you mean either
Cleaning the outside of the unit of dust and other marks etc
or
Flushing the inside of the radiator
Everyone should own a £25 inflatable bed pump saves me £ on canned air (which is incredibly overpriced).
As long as you have a narrow end or make one its almost as good as using compressed air.
