Haw-haw-haw-hawI don't like Reldar's definition of "dislike".
Chew on that for a while.
To say you 'don't like' something is to say you don't have positive emotion towards it. This does not mean you have negative emotion towards an object
It's funny how you keep breaking out the education jibes given how flat out wrong you are.
The phrase 'don't like' may have the popular connotation of what you're talking about, but in strictly orthodox interpretation you are incorrect to rule everything else out.
'Like' is a verb of positive emotion. To say you 'like' something is to say you have positive emotion towards it. To say you 'don't like' something is to say you don't have positive emotion towards it. This does not mean you have negative emotion towards an object, although as I said it may infer it.
The confusion with the OP's choice of words is down to popular connotation of phrase, not due to error.
This is not correct.[FnG]magnolia;18458944 said:It doesn't matter what your view is, you are incorrect. If you don't like Steve then you hold a negative opinion of him.
Just because you don't like something it doesn't mean you dislike it.
Well in my view "don't like" means: I have no positive feelings towards something.
But that does not mean you necessarily have negative feelings towards something.
Just because you don't like Steve. Doesn't mean you view him in a negative way.
"Dislike" always refers to negative views/feelings.
Correct is defined as: "free from error; especially conforming to fact or truth..." (Link)."This is not correct."
Ah, that doesn't mean that it's incorrect, it just means that you have no opinion on the matter.
Correct?
Hence the scale here is not personal, or relating to me or you, but is impersonal and based on correctness, i.e. from a scale reaching from very incorrect to completely correct, with some varying scale of accuracy or inaccuracy in between.
When I say this is not correct I am not addressing my interest at all in the matter, I am talking in impersonal absolutes. To tie this into the arguments above, I am ruling out the argument being 'correct' but I am not ruling out that there may be some element of truth in the argument nor am I ruling out the argument being completely wrong.
So in essence, if you're going for the smart**** angle - at least get it right.
Something is either correct, or it is incorrect, (it could be partially either, but it would have to be qualified as such).No, I'm sorry you're still incorrect.
You are assuming the negation of "correct" is "incorrect" (or "not correct"), when (according to your own logic) this isn't the case.
Or are you really disputing that the antonym of "like" isn't "dislike", or that "dislike" and "not like" don't mean the same thing? For most people and most common usages, they mean the same thing, and to not like something is to have negative feelings towards it. You can argue that this shouldn't be the case until you are blue in the face, that's fine, but arguing with the common use/misuse of words is pointless, much like "decimate" and "methodology" have come to be totally misused, but generally accepted with their new meanings.
[...]it's easier to use 'indifferent' or other vocabulary to be clearer.
There's a difference between being able to use something else to make it clearer, and stating that it's plain out wrong.See, we do agree. Argument over nothing!
There's a difference between being able to use something else to make it clearer, and stating that it's plain out wrong.![]()
No, if you say you don't like Steve, this means you dislike him. If you want to clarify specifically that you just have no positive feelings, you have to say 'I neither like nor dislike Steve'. Alternatively, as someone has already suggested 'I am indifferent towards Steve'. There is a reason why the word 'indifferent' exists...
As such negating one always implies the other.
You can either Like, Dislike or be indifferent to something.
As such negating any only implies one of the other two.
I don't dislike =/= I Like
I am not indifferent =/= I Like
I don't like =/= I dislike
It is common useage to use I don't like and mean I dislike, but that doesn't mean that's the only useage, seeing as it is in fact the less clear of two options.
