Power Supply Good Enough For GTX 580 SLI???
20 Jan 2011
I have the following system, and want to know if my PSU would be good enough to run GTX 580 SLI?
I5 2500k @ 4.8Ghz running on an a Asrock Fatal1ty Intel P67
3 X 2Gb G.Skill 1600Mhz @ 1.5v
3 X Ocz SSD's
1 X DVD Optical drive
1 X 200mm Fan
8 X 120mm Fans
1 X Laing DDC1+ Ultra 18W Pump
I have a Cooler Master Silent Pro Modular 850W would this be okay!?
Many Thanks
yes
Thanks for all your help.
Can I ask you something, is this forum electronically integrated into your brain or something?! As it must be like some sort of Heads Up Display, when any someone posts up a question, it pops up and alerts you in your head, so you can always be the first to post an answer! It's great; you always seem to be the one who answers all my questions. lol
Yes that's why the bot has to go to work and earn money. That is also why he has a niece because he is a bot.
Tested my single 580 with the system in my sig, running prime & Furmark together I was pulling 500w from the mains.
Also I have the Swiftech water pump.
The 480's were high power usage, pulled extra 115w~ with Furmark, I did not do the mod with Furmark when running the 580.
