grapic card
5 Jan 2011
i have just orderd a Intel Core i5 2500K 3.30GHz @ 4.60GHz DDR3 Sandybridge and a Motherboard: Asus P8P67 PRO Intel P67 (Socket 1155) DDR3 Motherboard plus a 600wat psu 1tb hardrive can you tell me what grapics card to get it will be for gameing
Another question. What size and resolution is your monitor?
Off the bat I'm going to say the 6950, but I'm quite sure that my recommendation will change after we learn more.
I'm assuming the 52" TV will have a resolution of 1920x1080, so I say go for the 570 or the cheap 480 on offer now. You could also go for a 6950 and unlock it to a 6970.
This one is £15 cheaper this week, and is the cheapest at the moment.
The EVGA as posted a little bit above is a good alternative too. 10 year warranty isn't something that you see everyday.
It's also something no one will ever use :p
2-5 years max for a GPU before you want to upgrade xD
kd
