Today Only, we have 20 units of Crucial RealSSD C300 64GB 2.5" SATA 6Gb/s Solid State Hard Drive for only £89.99 inc. VAT. The new 2.5" Crucial RealSSD C300 drive offers mobile and desktop users scorching-fast read speeds of up to 355MB/s and because it has no moving parts you will also enjoy a quieter, cooler, and more durable storage solution.
We also have 40 units of OCZ Platinum 4GB 1600MHz DDR3 Memory for just £28.79 inc. VAT. OCZ DDR3 ELV Dual Channel Kits are 100% hand-tested for quality assurance and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory kit is backed by the industry-leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
Crucial RealSSD C300 64GB 2.5" SATA 6Gb/s Solid State Hard Drive (CTFDDAC064MAG-1G1) @ £89.99 inc VAT
The new 2.5" Crucial RealSSD C300 drive offers mobile and desktop users scorching-fast read speeds of up to 355MB/s. And because it has no moving parts, you will also enjoy a quieter, cooler, and more durable storage solution. Designed with high-speed synchronous MLC NAND, advanced controller technology, optimized NAND management and the new SATA 6Gb/s interface, these drives dramatically improve data transfers for bandwidth-demanding applications like audio and video. The improvement in boot time and application load times push performance to new levels at the desktop too. You will experience improvement across a variety of common tasks such as viewing and editing photos, video, music and other media, gaming, communications, productivity and security.
- Capacity: 64GB
- Cache: 128MB
- Controller: Marvell 88SS9174
- Read: Up to 355MB/sec
- Write: Up to 70MB/sec
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA 6Gbps
- Low Power Consumption
- Shock Resistant
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Only £89.99 inc VAT.
ORDER NOW
OCZ Platinum 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Ultra Low Voltage Dual Channel Kit (OCZ3P1600C9ELV4GK) @ £28.79 inc VAT
OCZ Extreme Low Voltage (ELV) DDR3 kits are designed specifically for the Intel® P55 Chipset and subsequent Intel® Core™ i7, i5, and i3 (Socket 1156) processors. Configured for dual channel mode, these ultra-compatible 4GB kits ensure optimal performance with an ideal combination of improved lower power requirements, high speeds, and latencies.
Developed for enthusiast platforms that are becoming increasingly more power-efficient, OCZ ELV Dual Channel solutions are the choice counterparts for leading-edge performance, allowing high-speed memory to function farther below the upper voltage thresholds of Core i3 and i5 CPUs, operating at a blazing 1600MHz CAS 9 requiring only 1.35 Volts. OCZ ELV memory helps lower internal case temperatures along with your utility charges as less power is required for high frequency DDR3, offering incredible stability at stock speeds along with substantial overclocking potential.
Developed for enthusiasts and gamers making use of the latest technologies, OCZ ELV modules were engineered with the same affordability and performance standards as the Lynnfield platform. By using sophisticated IC screening methods and qualifying on a variety of motherboards, OCZ DDR3 kits are the perfect complement for the P55 Chipset and choice CPU to deliver the maximum stability. Together, P55 and OCZ memory are the ideal dual channel option for cutting-edge desktops.
Specification:-
- Sandybridge compatible
- 1600MHz DDR3
- CL 9-9-9-24 (CAS-TRCD-TRP-TRAS)
- Available in 4GB optimized kits
- Unbuffered
- Platinum Layered Z3 XTC Heatspreader
- Lifetime Warranty
- 1.35 Volts
- 240 Pin DIMM
Only £28.79 inc VAT.
ORDER NOW
- Capacity: 64GB
- Cache: 128MB
- Shock Resistant
- Warranty: 3 Years
ORDER NOW
Specification:-
- 1600MHz DDR3
- Unbuffered
- Lifetime Warranty
- 1.35 Volts
- 240 Pin DIMM
ORDER NOW
