Employment Law.
31 Jan 2008
I have done my job for 10 years.
I haven't got a problem with being asked to do jobs out of my job description and have done them to my best ability.
Recently I've been coerced into being trained in said jobs as part of my every day job.
I have a contract which states I do XYZ.
They want me to do A to Z.
Where do I stand?
If you don't want to do the "new role" you've left it a bit late to tell them to do one as they'll pull "custom and practice" on you due to you having agreed to do them in the past.
Ask for a new job description to reflect your new responsibilities and make sure it's recorded in your performance apraisal correctly.
Tell them you hope the pay raise they're going to give you for doing the extra work is worth it.
Pay rises/promotions are usually awarded due to an increase in responsibility, not an increase in workload.
do you realise how things are in the job world atm? i'd do them if i were you aslong as they are not asking you to do stuff which requires extensive training that they are not willing to give
Why more money?
Unless the extra stuff you do is of a higher grade or will mean more time at work, then you should just accept that they are giving you more training. If they could pay you to do XYZ only then they would, clearly they need people to do A-Z.
Evolve or lose out :p
No doubt he does. I don't see a problem with having slight objections with increased responsibility that might be out of the scope of his job description with no increased reward (OP hasn't told us about the latter yet).
I've thought of that and will be.
Just want some direction and thoughts of people in the know.
Employers have the right to make reasonable changes to contracts:-
Employees are expected to adapt to new working methods or techniques, but this must not alter the work that the employee is required to do to such an extent that the work involved is no longer of the kind they were employed to do.
Have a think about whether this is a reasonable change and if it significantly changes your original role.
You do realises that those two things are synonymous with each other, right?
No they are not. As I've (and many others) been promoted I've had an increase in responsibility but my workload (and hours) has reduced.
To increase someone's workload is to increase their responsibility. They are now responsible for more workload after all. :)
To try and sell it any other way is a manager's conjuring trick.
I do realise how things are in the job world atm and so do employers and I feel that I and amongst others are being taken advantage of.
Three years ago, I wouldn't be asking for this advice.
Crisp pakcer A packs 400 bags in 7 hrs on a normal day.
Crisp Packer B does the same.
Mgmt now wants crisp packer A to pack 450 bags in the same 7hr day.
They also want crisp packer B to monitor crisp packer A's work - effectively making them a line manger, but due to the exta work, crisp packer B will only have to pack 350 bags a day themselves.
Who deserves a pay rise/promotion?
They both do.
However, packer C packs 400 bags a day, but has now been asked to pack 300. In the spare time he now has, he has to move the 300 bags to another area.
Packer c (the op in this case) does not deserve a payrise :p
Neither do, it is simply a restructuring of work practices.
