Like i said it's fine if you accept that what you're doing amounts to mathematical trickery but doing such calculations in reality is impossible due to the infinity issue.
Squaring root 2 is not mathematical trickery
x = 0.9r
10x = 9.9r
9x = 9.9r - 0.9r
9x = 9
x = 9/9
x = 1
Squaring root 2 is not mathematical trickery![]()
Tell me, what is 1 - 0.9r?
Anything that deals with infinity is, by essentially cheating and not doing the real calculation.
An inexpressible number. That doesn't prove your point. 1/3 is simplified to 0.3r in decimals but that is just that, an approximation. The idea of recurring is to express the fact that we cannot represent the number accurately.
Think of it this way. If 0.9r = 1 then at what point does it equal 1. Recurring relates to the infinite nature of the value recurring, so how can something that by its very nature has no set value equal something that does have a set value.
(9) = the (infinity - 1) decimal number
I'm using != to mean not equal to, because I don't have a key with an equals sign that has a line through it.
I think this is where you run into trouble.![]()
Why?
infinity - infinity is 0.
Infinity - infinity + 1 is 1.
The only way that 0.9r = 1 is in theoretical maths.
Infinity doesn't work like that.
How does it work?
it is a theory anyway.
And if infinity is the end, then there has to be a number before it,
it can't just count like:
1, 2, 3, 5 billion.
there has to be a number before it Always, just like there is always a number before any number. (except negative infinity)
How does it work? ... if infinity is the end, then there has to be a number before it,
All the time! 0.9r only has one value.
Thats a little pedantic. Of course 0.9r is the value 0.9r. But you would never hit the value 1 with 0.9r. You cannot express a number between 0.9r and 1 but I can't see how that is relevant.
That is a little akin to saying "using whole numbers, give me a number between 5 and 6. It can't be done.
The nature of infinity means that it will never hit the next number in the sequence. 0.9r will never be 1 until you get bored and round.
I should have called this thread, 'does 0.9r = 1'![]()
