I've been having various issues with Win7 lately, mainly turning on and having just a blank screen with a cursor which always seems to happen after an update (get update > install update > turn system on > reboots and works fine > shutdown and try and turn on but nothing).
I just got back from work and turned my PC on to be greeted by the "This Windows is not genuine" screen, I've not had an issue with this at all and I have my box sitting next to my PC (because the only way to get back to a usable PC after the blank screen issue above is to use the disc and system restore). I'm not sure if this is a common issue or if it's even fixable; I'd much rather not have to re-install if I could as I don't get much time at home lately and the time I do get I don't want to be messing with my PC, however if it's the only real fix then I guess it'll be the answer.
Background on my system, 7 has been installed on this system twice, currently on here for just over a year now. MalwareBytes and Spybot report nothing as usual, haven't really installed anything lately either programs or drivers, infact the only thing that has changed is from Windows Update and the fact I disabled it couple of nights ago to avoid my above problem. Hardware wise the only thing that might even be relevant to the hanging issues is one of my hard drives is on its way out (music, not system).
Anyone have any suggestions or is it just a nuke and install jobby?
Edit: I've seen plenty of pirated XP and Vista installs when I was a technician, the screen I saw didn't look like them for the record, but didn't look like the common virus which pretends to be a pirate install of Windows.
