So remind me hows it working out trying to run your current car on a budget?
Brilliantly, do you want a break down of 'major' costs over the last 9 months?:
New Tyres (KU31 Kumhos, couldn't source the Federal RSRs I wanted) went on two weeks ago - £350 front and rear
Front anti roll bar bushes to cure a squeak - £20
Oil, filter and plug change (Every 3000 miles) - £45 x2
£20 of V Power does me between 30-40 miles. I don't drive during the week due to parking so that lasts me a week easy (although according to P.H I've still done £1,500 on fuel this year
£125 on a genuine Denso O2 sensor a couple of months back
£84 on Rear Pads (Yellow stuffs) and Discs
S/H Pass Door card, door latch and Driver's Seat belt - £50
Replacement Radiator - £100
PCV valve recall and Gearbox strainer - £100
Insurance - Quite bad first year. Halving this month
Tracing and removing 3rd party alarm system - £Free, but if I had a swear jar I'd be down a few grand
Off of the top of my head the car NEED anything doing to it but there is a lot of stuff that I want to do. Body work is still tatty, it needs some work to make it suitable for more track days and the "Woah" factor when flooring it isn't quite there anymore, but maintenance wise it is in good health and (for the performance) it has been what I'd consider pretty cheap. You can make your own decisions, but if I can afford it, anyone can!
