Thought I would try my hand at watercooling. A few months ago, I bought an EK bay res, Laing D5 and a 360 rad from the MM.
Also ordered some black round akasa cables for drives, some compression fittings (3/8" tubing) some tubing (clear) all 3/8"
Then decided to invest in a Corsair 700D. So far so good.
Ordered 5 120mm Sharkoon fans (Silent Eagle) 3 for the rad, and 2 to replace the others in the case.
First hurdle: 2 of the corsair fans are 120mm. Bugger! My fault.
Second hurdle, the EK res doesn't have the grooves for the 5 1/4" bay shelf bits! Not modding my case, so changed the res.
Went for the EK multioption res and the i7 block. (Nickel)
I thought I could get the 3/8" tubing over the D5 barbs. Was not to be! Tried allsorts. So thaought, OK, change of plan! Go for 1/2" tubing (white). Ordered some silver barbs to match the block, and some black EK ones to match the rad and the res. Also some black clips to keep the pump connections good.
Starting to cost me now!
Project was on hold for a few weeks. Just came to start assembly.
1st hurdle, the D5 DOES NOT fit under the 700D next to the PSU. SOD! Looked for alternate mounting points and consulted google. There is an acetal top for it. Bingo, will go for that (More money!)
Decided to install the rad. Of course, it has silver sides, and I don't like it, plus its damaged from the project being on hold for awhile! Give up. Decide to order new one (along with the new D5 top!)
Even the EK block, the silver fittings I ordered are way to big of a diameter to get both on there . . .
Went to install multioption res. The EK compression fittings DO NOT fit on the sides of the res. They screw in, but the spot facings on the side of the res are not big enough, the O-Ring will not seal. GRRRR. Will have to mod this now! Either alter the fittings, or get the sides milled bigger, I have not yet decided!
Also, I think the watercooling holes in the bottom compartment of the 700D are in a monumentally stupid position!
Its cost me a bloody fortune this water cooling malarky!
I am also frustrated by the monkeys at EK, why oh why do their own fittings not fit their reservoirs? Seriously, did they even TEST these? Did no one try it at all?
Frustrating.
