you normally (on new psu's anyway) get the old style 20pin (i think) connector with the 4pin addons, and then the 4pin cpu connector with an extra 4pin connector for mobos that need it.
think im right in the numbers, either way, yes, all new psu's should fit all mobos (unless you buy an ITX mobo)
OK, but will they all be compatible with the higher end graphics cards? The dual card ones??
Thanks..
Thanks..
Hi, I want to order a 700W to 800W power supply for a new build and i keep reading about the different motherboard connections for the different boards.
Are all the PSU,s compatible with all the motherboards?
Thanks..
Hi, I have a Haf X case, and i want to get the new I7 sandybridge when they sort it outm on a ASUS motherboard probably the pro. Also i will be using a new Vertex ssd for the opperaing system with 2 1Tb Samsung spinpoint drives for storage (got them too).
DVD burner. And a decent graphics card (£200ish).
The psu i was thinking of is the Coolermaster Silent pro 850W.
http://www.overclockers.co.uk/showproduct.php?prodid=CA-193-CM&groupid=701&catid=123&subcat=1103
Whats your thoughts
Thanks
coolmaster site said:M/B 20+4 Pin Connector x 1
CPU 4+4 Pin x 2
PCI-E 6+2 Pin x 6
4 Pin Peripheral x 6
SATA x 9
4 Pin Floppy x 1
OK, thanks a lot.
Is there anything else you would recommend before i buy it??
