***** New lines in from Sharkoon ***** BUY NOW!
20 Jul 2009
The bleak North East arm pit of Britain
OcUK have today got some fantastic new Sharkoon lines in the form of docking stations and controller cards. BUY NOW! :D
Sharkoon SATA QuickPort Mini USB3.0 with Sharkoon USB3.0 expansion card @ £41.98 inc VAT
With the SATA QuickPort Mini, we introduce the little brother of the well-known SATA QuickPort.
The miniature docking station is suitable for 2.5” SATA hard drives and SSDs in the appropriate format.
The connection of the device is via the provided USB3.0 cable, which also simultaneously serves as the power supply.
The SATA QuickPort Mini has an LED indicator for power supply and hard drive access as well as an on–off switch on the back.
- Enables the direct connection of a SATA HDD to your PC via USB3.0
- Suitable for 2.5" SATA HDDs
- External interface: USB3.0 (max. 5 Gbit/s)
- Downward compatible with USB2.0 and USB1.x
- Premium workmanship
- On/Off button
- LEDs for power and HDD access
- Dimensions: 95 x 55 x 45 mm
Contents
- SATA QuickPort Mini USB3.0
- USB3.0 cable
- Manual flyer
Sharkoon 2-Port USB 3.0 PCI-Express Card
Ten times faster than the USB2.0, data transfer rates of up to 5Gbps, enhanced transmission reliability and energy efficient: The new USB 3.0 interface now also offers an over abundance of bandwidth for data transfer applications. Sharkoon are the first provider to immediately offer a PCI-e controller so that your PC can be quickly and efficiently upgraded: The USB3.0 Host Controller Card is equipped with a NEC µPD720200 chip; the two USB 3.0 Ports are combined with the PCI-e 2.0 so that it can conform to Intel xHCI-rev0.96 specifications. The controller card connect directly to a PCI-x1 slot; it is powered via a 4-pin molex plug, and is supported by Windows XP, Windows Vista, and Windows 7.
- Enables the connection of USB 3.0 devices to your PC
- Downwards compatable with USB2.0 devices
- PCI-E 1x Slot
- External Connectors: 2 x USB3.0
- Supported by Windows XP/Windows Vista/Windows 7
- 4 Pin Molex Powered
Only £41.98 inc VAT.
ORDER NOW
Sharkoon SATA QuickPort Mini USB3.0 @ £17.99 inc VAT
- On/Off button
Contents
- USB3.0 cable
- Manual flyer
Only £17.99 inc VAT.
ORDER NOW
Sharkoon SATA QuickPort Mini USB2.0 @ £14.99 inc VAT
The miniature docking station is suitable for 2.5" SATA hard drives and SSDs in the appropriate format.
The connection of the device is via the provided USB2.0 Y cable, which also simultaneously serves as the power supply.
- Enables the direct connection of a SATA HDD to your PC via USB2.0
- External interface: USB2.0 (max. 480 Mbit/s)
- On/Off button
Contents
- USB Y cable
- Manual flyer
Only £14.99 inc VAT.
ORDER NOW
Sharkoon SATA QuickPort Duo -v.2- @ £43.99 inc VAT
Two SATA HDDs can be inserted into the revised version ("version 2") of the SATA QuickPort DUO: 2x 2.5" or 2x 3.5" or 1x 2.5" and 1x 3.5". PCs connect via USB or one fast eSATA connection.
Provides the direct connection of two SATA HDDs to your PC
Suitable for 2.5" and 3.5" SATA HDDs
External interface: 1x USB 2.0 and 1x eSATA
Premium workmanship
Supported operating systems: Win XP/Vista/7 (32-bit and 64-bit), Mac OS
Dimensions: 148 x 132 x 71 mm (L x W x H)
Weight: 533 g
Package contents:
- SATA QuickPort Duo
- Power adapter
- USB2.0 cable (length: 150 cm)
- eSATA cable (length: 100 cm)
- Short manual
Only £43.99 inc VAT.
ORDER NOW
Sharkoon SATA QuickPort Duo USB3.0 -v.2- @ £56.99 inc VAT
Like the other SATA QuickPort Duo models two SATA Hard Drives could be inserted into the device: 2 x 2.5", 2 x 3.5", or 1 x 2.5" plus 1 x 3.5".
Connection to the PC shall be made exclusively through the devices rear side USB3.0 port.
- Provides the direct connection of two SATA HDDs to your PC
- Suitable for 2.5" and 3.5" SATA HDDs
- External interface: 1x USB3.0
- LEDs for power and HDD access- Supported operating systems: Win XP/Vista/7 (32-bit and 64-bit)
- Dimensions: 148 x 132 x 71 mm (L x W x H)
- Weight: 519 g
Package content:
- Power adapter
- USB3.0 cable (length: 100 cm)
- Short manual
Only £56.99 inc VAT.
ORDER NOW
Sharkoon SATA QuickPort XT USB3.0 @ £23.99 inc VAT
With the SATA QuickPort XT USB3.0 we offer a docking station for SATA hard drives in classic black (with red lighting) and modern white (with blue lighting).
The hard drive dock provides a module slot for a 2.5" or 3.5" SATA hard drive and, of course, 2.5" Solid State Disks can also be used with the SATA QuickPort XT.
The hard drive station can be connected through a fast USB3.0 port.
For safety concerns the device offers a backup function in which the provided software can quickly and easily be installed and configured on the computer.
- Downwards compatible with USB2.0 (High-Speed)
- One click backup function
- On/off button
- Dimensions: 130 x 100 x 63 (L x W x H)
- Weight: 313 g
- Color versions: black and white
Package Contents:
- SATA QuickPort XT USB3.0
- Power adaptor (12 V/2 A)
- USB3.0 cable (100 cm)
- Short manual
- Tools CD
Only £23.99 inc VAT.
ORDER NOW
Sharkoon SATA QuickPort XT USB3.0 Plus @ £35.99 inc VAT
Besides the regular package contents the Plus version of our SATA QuickPort XT USB3.0 additionally features a USB3.0 Host Controller Card with two USB3.0 interfaces.
Features SATA QuickPort XT USB3.0:
- On/off button
- Weight: 313 g
Features USB3.0 Host Controller Card:
- USB3.0 (SuperSpeed) host controller card
- Enables the connection of USB3.0 devices to your PC
- External interface: USB3.0 (max. 5 GBit/s)
- External connectors: 2x USB3.0
- Mainboard connector: PCIe 1X
- Output voltage: DC 5 V
- Output current: 900 mA/port
- Supported operating systems: Win XP/Vista/7 (32-/64-bit)
Package Contents Plus
- USB3.0 Host Controller Card
- Power adapter (12 V/2 A)
- Short manual
- Tools CD
Only £35.99 inc VAT.
ORDER NOW
Sharkoon 2-Port USB 3.0 PCI-Express Card @ £23.99 inc VAT
- PCI-E 1x Slot
ORDER NOW
For the extra £12 over the price of the card alone, that last one would be a useful little gadget to have lying around.
Unfortunately, most of my old HDDs are IDE (I'm a hoarder).
Anyone have any of these? Wouldn't mind using 1 for storing movies and then playing them directly from there too, just wondering what they would be like temperature wise, safe enough I guess but for prolonged use? (got 712gb of movies to move onto drive(all legit)) Would be the Sharkoon SATA QuickPort XT USB3.0 I would order
This is probably a pretty stupid question but hopefully a valid one....do the USB3 controller cards work with regular USB extention cables? Or do you need an extention cable that's cable of USB3?
