My GTX 580 is a tad noisy for my taste considering my CPU is cooled with the corsair H50 and some pretty quiet fans. At stock I have seen the temps go up to 89 degrees as well and I can't overclock the card at all really without problems.
So I am looking for recommendations for an aftermarket cooler with an emphasis on low noise but also so that I can get some nicer temps. Unfortunately my case is a midi tower that only fits cards/coolers up to 285mm (Lian Li PC-8FIB) so this rules out the Accelero XTREME Plus (290mm) unless there is a workaround.
I'm not absolutely desperate for this but I just want to know what the options are.
. The yellow lines is the foam, green is cable ties.
