Might Be Going For This System Soon - Any Advice
9 Jul 2009
Titan Triceratop" Intel Core i5 2500K 3.30GHz @ 4.40GHz DDR3 Sandybridge :D:D
Using for Photoshop CS5 & watching movies and a little gaming ect
Reason i have gone for a pre-built system as i am not yet confident to build my own :D
http://www.overclockers.co.uk/showproduct.php?prodid=FS-179-OE&groupid=43&catid=1444&subcat=1712
upgrade options are
Windows 7 home premium 64 bit
HD-364-WD Western Digital Caviar Blue 500GB SATA 6Gb/s 16MB Cache -
OEM (WD5000AAKX)
Samsung SH-B123L/BSBP 12x BluRay ROM DVDRW DL & RAM
Lightscribe SATAII Optical Drive - OEM Black
Looks good, but the motherboard will mean you won't have dual GPU support, but then again if you don't that it makes no difference! There's a build guide on ocuk though, it's really helpful, might make you reconsider building one yourself.
