Caporegime
- 12 Mar 2009
What was your team killswitch? I'll have some players!!
They've all gone now.
Sold them this afternoon! Next time I decide to change I'll offer here first. Made another Serie A team.
Pffft!
I need to sell my greasy... Umm, I need to sell my Spaniards before I can really afford any more players. Got a bid in for Neuer and I've bought Raul, Rakitic, Metzelder, Podolski and Huntelaar so far. I might get Diego later as for his price he has crazy stats. <3 !!
They're pointless. If you want to win, pass.
Agreed - like any decent footballer that can do tricks, you very rarely see them in a proper game of football...
Learn his style, mix up your play/attacks and dont force chances...
Use skill dribbling and fake shot/pass judiciously and youll be fine
ps3ud0![]()
The only tricks I use are:
The double tap in the direction you're moving to flick the ball up and forward at waist hight which is a good one to use down the line when a player is coming at you from an angle or even outside the box to just blast a volley towards goal.
The heel chops where you flick the stick diagonally backwards to your direction of movement to cut the ball inside/outside an oncoming defender which opens up space for you as you take them out of the game.
Both of these tricks are fast completed skills that are usually over quickly enough for you to get a shot away or choose your next direction of run/pass before the next defender is on you.
I use skills in game, but only a select few work more often than not.
The best tricks to use to cut in from a wing position are the fake shot, which i've only recently got the hang of and find it ludicrously easy to dribble into the box with, and the McGeady spin. That one requires more practise and is more about timing. To do it just flick the stick the way your travelling then flick 90 degrees in either direction, depending on which way you want to go.
The only other trick I use is the quick flick of forward and back, I think it's called the heel clicker. That one is best used on the left side when you've fed a striker/winger in behind a wing back with a CB closing you down, if u drop it at the right time, just as they get near, you can totally take them out the game. For extra effect be running on a slight diagonal up.
It's all about timing and like I said it's easier if they are coming at you from a slight angle. I tend to initiate the trick when the defender is lunging in for the tackle.Cheers, why does the flick up work against a defender coming at you? Surely they would just chest it away from you?
Ah it's okay, I haven't got a full team, no idea which team/league I want to base my squad on. I've only got Pato and Ronaldinho and Arsene Wenger at the moment, all with the 4-3-2-1 formation. Ronaldinho is LF and Pato RF, I was thinking of another Brazilian ST for the middle and then padding the rest of the squad out with Prem players. Chemistry might take a slight hit with the front three not playing in the same league as the rest of the squad but I have no idea what else to do. Toyed with the idea of a Brazil International team but they don't seem to have great quality in the centre of the pitch, apart from Kaka who is out of my price range.
