- 21 Dec 2010
- Glasgow, Scotland
Hey folks, so im running Metro2033 on max and im getting GPU temps of 80-95. Is that too high or normal for being under load?
Thanks
Thanks
thats quite highHey folks, so im running Metro2033 on max and im getting GPU temps of 80-95. Is that too high or normal for being under load?
Thanks
Cranked the fan up to 60% using EXPERTool that came with the 570. Now it runs at around 78 under load. Is it safe to put your GPU fan on 100%? Or would this shorten the lifespan or something?![]()
U always find just the right answer stulidThanks again. Now the thermal grease? Just a pea sized amount? Or a thin line?
