Ah cool. There should be an OcUK team
We could set up an LTUK vs OcUK "clan" match at some point for the acheivement if we had enough interest. Just set one steam group as ur primary, other team set the other one, and away we go.
I do have a server lying around if you want to use it at some point. 5UB has used it before...
@ 5UB: I used INX inb the past, technical support was brilliant, but I only found that out as I always had to use it all the time as the servers kept going down (hardware fault or something else I had no control over. They aren't cheap either.
GTX Gaming are worth looking at as you can get a good deal with them. They are good at support and don't go wrong too often either, unfortunately ftp app support is terrible, making it more difficult to upload files to them.
Finally there is Gameservers.com. Technical support is not quite as quick as the other two but they have good prices, 3rd party support and are reasonable stable compared to INX. You also don't have to pay to remove their branding.
Oh yeh there are Multiplay, but you have to pay for unbranding and they are comparatively expensive compared to Gameservers.com and GTX Gaming (like INX). Their 3rd party app support is odd as well, but they were the most stable I have used.
Pick the one you like the sound of the most. For me it would be a toss up between Multiplay and Gameservers.com.
