Antec TruePower 650W or 750W?
8 Jan 2010
Which PSU would suit me best for this spec please? only £20 a difference but still. Here is what I would be ordering:
MSI GeForce GTX 560Ti OC Twin FrozR II 1024MB GDDR5 PCI-Express Graphics
Intel Core i5-2500K 3.30GHz
Asus P8P67 PRO
Corsair A70 High-Performance Dual Fan CPU Cooler
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
Plus maybe 3 HDD and 2 External HDD and usual accessories.
Thanks
650w will be fine I would have thought. Pretty sure ive seen them for 69.99 somewhere, so the difference is more like £40
ok thanks will go for the 750w then, any other brand I should check out at a similar price point of £110. Had problems with 2 corsair psu's failing and sending them away to the Netherlands for RMA was not cheap either, so avoiding them now.
I had a lot of issues with Antec PSU's in the past but this was 3-4 years ago. If they are indeed using Seasonic units now, there shouldn't be any issues.
